Legato 3 opamp rolling
Hi!.
Last week-end I tried an old Burson discrete opamp replacing the LM4562 in my Legato 3.1. Changes were not subjective. I will not discuss wich one was better or worse because I think that this is a matter of taste. I only want to think in other potential candidates for opamp rolling.
Russ, which was the reason for choosing LM4562?. Stability?, Musical performance?.
I would like try AD797BRZ (two in dual DIP adapter) but I have read that this need a special configuration to operate properly. What do you think about?.
Another possible candidate would be LME49990....
Regards.
Ignacio.
