LeeHee Audio TDA1541A DAC Digital to Analog Converter
New unused LeeHee Audio Studio TDA1541A DAC. Latest version series 8. 4x oversampling; coaxial, optical, and USB inputs. NOS mode is possible with the correct module to replace onboard SAA7220/B digital filter chip. USA model 115-volt AC input. I am the original purchaser and this item has never been used in any way so it is untested. Top cover has 2 spots where the factory anodizing is slightly uneven where it looks like scratches but they are not. No documentation came with this DAC, so I do not know if a software driver is needed for USB capability. USB module is XMOS U8 based. $400 plus shipping.
I have an NOS module along with a 96kHz digital receiver chip available.
Technical specs: Digital input 16-bit 32KHz, 44.1KHz, 48KHz; Frequency response: 10Hz~22kHz +/-0.5dB; Dynamic range: 96.5dB; Total harmonic distortion 0.002% @1kHz; Intermodulation distortion: 0.004% @12-14K; Channel separation: -97dB.
Sold "as-is" and no warranty is expressed or implied. No returns or refunds. Sells and ships to USA residents only.
