LED/RESISTOR COMBO for AudioSector LM4780
I simple question to Peter if he has time or anybody who may have experience with this kit.
The LED's are just for status display and so don't need to light up much, I would prefer to use the lower output units if possible.
I have these 2 LED's on hand but have no idea what value resistor to use with it. I have 10/20/30/40/50/60/70/80/90/100k RN55D resistors on hand.
LED-1
AVAGO TECHNOLOGIES|HLMP-KA45-E0000|LED, 3MM, INGAN, BLUE | element14 Australia
or
LED-2
VCC (VISUAL COMMUNICATIONS COMPANY)|VAOL-3GSBY4|LED, 3MM, BLUE, 2500MCD, 470NM | element14 Australia
Cheers all.
Getting close now
Dean
If you are conecting it to about 30v using a RN55D size resistor you can use anything
from about 4k up. Using a 4k resistor would be kind of bright a 100k resistor would be sort of dim. If you just want a rather dim light I would be tempted to start with a 40K
resistor and go from there.
