Does anyone have PCB layouts for the leach amp that has the output transistor on the PCB? I am looking for a design that is better than the on on Mr. Leach's website
I can accept basically any type of drawing.
Thanks in advance
Johan Wagener
200234315@ctech.ac.za(removethis)
Thanks in advance
Johan Wagener
Leach amp PCB with output transistors
try this thread (Found via the search function in under 30 seconds 🙂):
http://www.diyaudio.com/forums/showthread.php?s=&threadid=4091&highlight=
\Jens
\Jens
Wagener said:Does anyone have PCB layouts for the leach amp that has the output transistor on the PCB? I am looking for a design that is better than the on on Mr. Leach's website
What do you mean by "better" The main reason the PCB by Dr Leach doesn't have transistors on the PCB is that he chose TO-3 transistors instead of TO-220 or TO-247's.
Danny
well. I am looking for a layout that has the to-3 mounted on the pcb.
Why would he not have placed them on the pcb? Its not that hard to heatsink the transistors on a pcb?
Thanks for the replies
Heatsinking To3 on PCB
Hello,
The reason maybe that the PCB size gets (alot) bigger when you start to mount output transistors on it.
Also if you want to have your output on the PCB I suggest that you put them in line parallel to the heatsink, and use an "L" profile to transfer heat to the heatsink.
There might wery well be another reason that Dr. Leach used output transistors mounted with wires away for the PCB, simply the fact that the L profile is less than optimal seen from a thermal point of view.
\Jens
Hello,
\Jens
Links to boards with integrated TO-3 devices:
http://home.swipnet.se/malman/LeachAmp.html
http://www.diyaudio.com/forums/showthread.php?s=&threadid=2289&highlight=
http://www.diyaudio.com/forums/showthread.php?s=&threadid=29234&highlight=
Brian
Brian
Hello,
I am quite new memeber in this forum. But I have made leach amp with my own pcb design many unit. I can say that this is the best amp I had ever made. This is my pcb design with output TO-3 (2SC5200/2SA1943)on the board.It is in protel format. Have fun!!
Kon: What is the file format *.pcb in your zip file ??? (TIF ? JPEG or something more special ?)
Greetings
Herman
Greetings
Herman
- Leach amp pcb's
