Lcd bargraph
I found a nice library for LCD bargraphs and wanted to use it in some project.But it was not written in JAL, so I tried to convert it, but something is not working.
Anyway here is what I have:
This is for Bascom AVR
'* Creates a variable sized BAR-graph anywhere on the screen *
'* Name : LCDbar_INC.bas *
'* Author : Darrel Taylor *
'* Notice : Copyright (c) 2005 *
'* Date : 9/8/2005 *
'* Version : 1.0 *
'* Notes : Maximum Range is 32768 *
'* : Range must always be a Constant *
'* : Value must always be a WORD variable *
; default
BAR_width VAR BYTE : BAR_width = 16 ; Width of the BARgraph 16
BAR_range VAR WORD : BAR_range = 100 ; Range of Values (0-100) 100
BAR_row VAR BYTE : BAR_row = 1 ; Row location (1-4) 1
BAR_col VAR BYTE : BAR_col = 0 ; Column location (0-15) 0
BAR_value VAR WORD : BAR_value = 0 ; Current BAR value 0
BAR_style VAR BYTE : BAR_style = 1 ; 1=lines, 2=boxed, 3=blocks 1
; --- Temporary vars ----
BARtemp VAR WORD
Remainder VAR WORD
BARloop VAR BYTE
LastCharset VAR BYTE : LastCharset = 0
Limit1 VAR WORD
GOTO overBAR ; Skip over Subroutines
ThreeBARS CON 0 ; Identify the Custom Characters
TwoBARS CON 1
OneBAR CON 2
ASM
lines = 0x10000001 ; Define the Styles
boxed = 0x10000002
blocks = 0x10000003
ENDASM
; --- lines Style custom chars ----
CharsetLines:
LCDOut $FE,$40,REP $15\8 ; Custom char 0 - 3 lines |||
LCDOut $FE,$48,REP $14\8 ; Custom char 1 - 2 lines ||
LCDOut $FE,$50,REP $10\8 ; Custom char 2 - 1 line |
RETURN
; --- boxed Style custom chars ----
CharsetBoxed:
LCDOut $FE,$40,$1F,REP $15\6,$1F ; III
LCDOut $FE,$48,$1C,REP $14\6,$1C ; II
LCDOut $FE,$50,REP $10\8 ; I
RETURN
; --- blocks Style custom chars ----
CharsetBlocks:
LCDOut $FE,$40,REP $1F\8
LCDOut $FE,$48,REP $1C\8
RETURN
; ----- Show the BAR graph -----------------------------------------------------
ShowBAR:
IF BAR_width = 0 then BARdone
if LastCharset <> BAR_style then ; If the Style has changed ?
LastCharset = BAR_style
SELECT CASE BAR_style ; Load the new custom chars
CASE 1 : GOSUB CharsetLines
CASE 2 : GOSUB CharsetBoxed
CASE 3 : GOSUB CharsetBlocks
END SELECT
endif
@ ifdef LCD4X20
LOOKUP BAR_row,[$80,$80,$C0,$94,$D4],BARtemp
@ else
LOOKUP BAR_row,[$80,$80,$C0,$90,$D0],BARtemp
@ endif
LCDOUT $FE, BARtemp + BAR_col ; Move cursor to start of the BAR
BARtemp = BAR_value * BAR_width ; calc the char position
BARtemp = DIV32 BAR_range
Remainder = R2
For BARloop = 0 to BAR_width -1
SELECT CASE BARtemp
CASE IS > BARloop
LCDOUT ThreeBARS ; send 3 bars |||
CASE IS < BARloop
LCDOUT " " ; clear to end of BARwidth
CASE IS = BARloop
Limit1 = BAR_range * 6
Limit1 = DIV32 10
if Remainder >= Limit1 then
LCDOUT TwoBARS ; send 2 bars ||
else
Limit1 = BAR_range * 3
Limit1 = DIV32 10
if Remainder >= Limit1 then ; 30%
LCDOUT OneBAR ; send 1 bar |
else
LCDOUT " " ; no bars
endif
endif
END SELECT
NEXT BARloop
BARdone:
RETURN
ASM
; --- The main macro for creating BARgraphs ------------------------------------
BARgraph macro Value, Row, Col, Width, Range, Style
MOVE?CW Range, _BAR_range ; Range MUST be a constant
MOVE?WW Value, _BAR_value ; Value MUST be a WORD variable
if (Row < 5) ; Row is a constant
MOVE?CB Row, _BAR_row
else ; Row is a variable
MOVE?BB Row, _BAR_row
endif
if (Col < 16) ; Is Col a constant ?
MOVE?CB Col, _BAR_col
else ; NO, it's a variable
MOVE?BB Col, _BAR_col
endif
if (Width <= 40)
MOVE?CB Width, _BAR_width
else
MOVE?BB Width, _BAR_width
endif
if ((Style >= lines) & (Style <= blocks)) ; Is Style a valid constant ?
MOVE?CB Style, _BAR_style
else ; NO, treat it like a variable
MOVE?BB Style, _BAR_style
endif
L?CALL _ShowBAR
endm
ENDASM
overBAR:
And this the same for mikrobasic
Module LCD_BarGraph_16_Module
' Written by picmicroman for mikrobasic
' Based on darrel taylor code work
' Define styles
Const Lines = 1
Const Boxes = 2
Const Blocks = 3
' Define Bar numbers
Const Boarder = 3
Const OneBar = 2
Const TwoBars = 1
Const ThreeBars = 0
' 4X20 LCD
Const Row As Byte[5] = ($80,$80,$C0,$94,$D4)
' If 4X16 LCD is used, comment the above line
' and uncomment the following line...
'Const Row As Byte[5] = ($80,$80,$C0,$90,$D0)
' Global Variables here
Dim BAR_Style, BAR_Loop As Byte
Dim Remainder As Word
Dim BAR_Temp As LongInt
' --- Lines Style custom chars ----
Sub Procedure CharSetLines
Dim Fvar As Byte
LCD_Cmd($40) ' Go to CGRAM location 64
For Fvar = 0 To 7
LCD_Chr_CP($15) ' Custom char 0 - 3 lines |||
Next Fvar
LCD_Cmd($48) ' Go to CGRAM location 72
LCD_Chr_CP($15)
For Fvar = 0 To 5
LCD_Chr_CP($14) ' Custom char 1 - 2 lines ||:
Next Fvar
LCD_Chr_CP($15)
LCD_Cmd($50) ' Go to CGRAM location 80
LCD_Chr_CP($15)
For Fvar = 0 To 5
LCD_Chr_CP($10) ' Custom char 2 - 1 line |::
Next Fvar
LCD_Chr_CP($15)
End Sub
' --- Boxes Style custom chars ----
Sub Procedure CharSetBoxes
Dim Fvar As Byte
LCD_Chr_CP($1F)
For Fvar = 0 To 5
LCD_Chr_CP($15) ' Custom char 0 - 3 lines III
Next Fvar
LCD_Chr_CP($1F)
LCD_Chr_CP($1D)
For Fvar = 0 To 5
LCD_Chr_CP($14) ' Custom char 1 - 2 lines II:
Next Fvar
LCD_Chr_CP($1D)
LCD_Chr_CP($15)
For Fvar = 0 To 5
Next Fvar
LCD_Chr_CP($15)
End Sub
' --- blocks Style custom chars ----
Sub Procedure CharSetBlocks
Dim Fvar As Byte
For Fvar = 0 To 7
LCD_Chr_CP($1F) ' Custom char 0 - 3 block |||
Next Fvar
LCD_Chr_CP($1D)
For Fvar = 0 To 5
LCD_Chr_CP($1C) ' Custom char 1 - 2 lblock ||:
Next Fvar
LCD_Chr_CP($1D)
LCD_Chr_CP($15)
For Fvar = 0 To 5
Next Fvar
LCD_Chr_CP($15)
End Sub
' --- Dots boarder custom chars ----
Sub Procedure CharSetDots
Dim Fvar As Byte
LCD_Cmd($58) ' Go to CGRAM location 88
LCD_Chr_CP($15) ' Draw a three dots . . .
For Fvar = 0 To 5
LCD_Chr_CP($00)
Next Fvar
End Sub
' --- custom chars ----
Sub Procedure Char_Set(Dim Style As Byte)
BAR_Style = Style ' Remeber last used CharSet
Select Case Style ' Load new custom chars if style is changed
Case 1
CharSetLines
Case 2
CharSetBoxes
Case 3
CharSetBlocks
Case Else
CharSetLines
End Select
End Sub
' --- custom chars are loaded from here at start up ----
Sub Procedure LCD_BarGraph_Init
' Bar graph is initialized to lines at start up
BAR_Style = Lines ' 1 = Lines, 2 = Boxed, 3 = Blocks
Char_Set(BAR_Style) ' Load custom chars when PIC is 1st powered on
CharSetDots ' Load boarder dots
End Sub
' --- Bar Graph complicated calculation are isolated here ----
Sub Procedure Calculate(Dim BAR_Value As Word,
Dim BAR_Width As Byte,
Dim BAR_Range As Word)
BAR_Temp = BAR_Value * BAR_Width
Remainder = BAR_Temp Mod BAR_Range
BAR_Temp = BAR_Temp DIV BAR_Range
End Sub
' --- Bar Graph is drawn here ----
Sub Procedure LCD_BarGraph_Draw(Dim BAR_Value As Word,
Dim BAR_Row As Byte,
Dim BAR_Col As Byte,
Dim BAR_Range As Word,
Dim Style As Byte)
Dim Limit As Word
If BAR_Width = 0 Then ' If BAR_Width = 0, do nothing
Exit
End If
If Style <> BAR_Style Then ' If style changed, the load the
Char_Set(Style) ' new style to LCD CGRAM....
End If
BAR_Temp = Row[BAR_Row] ' Define at which row the bar is
LCD_Cmd(BAR_Temp + BAR_Col - 1) ' Move cursor to bar grpah start
Calculate(BAR_Value, BAR_Width, BAR_Range) ' Make complicated calculations
For BAR_Loop = 0 To (BAR_Width - 1)
If BAR_Temp > BAR_Loop Then
LCD_Chr_CP(ThreeBars) ' Send 3 bars
End If
If BAR_Temp < BAR_Loop Then
LCD_Chr_CP(Boarder) ' Clear to end of bar width
End If
If BAR_Temp = BAR_Loop Then
Limit = BAR_Range * 6
Limit = Limit Div 10
If Remainder >= Limit Then
LCD_Chr_CP(TwoBars) ' Send 2 bars
Else
Limit = BAR_Range * 3
LCD_Chr_CP(OneBar) ' Send 1 bar
Else
LCD_Chr_CP(Boarder) ' No bars sent
End If
End If
End If
Next Bar_Loop
End Sub
End.
And this is my conversion for JAL v2, but it does not work.
-- Module LCD_BarGraph_16_Module
-- Written by picmicroman for mikrobasic then changed for jal
-- Based on darrel taylor code work
-- How to use
-- Value Row, Col, Width, Range , Style
-- LCD_BarGraph_Draw( Value , 1 , 1 , 16 , 255 , Lines )
-- LCD_BarGraph_Draw( Value , 2 , 1 , 16 , 255 , Boxes )
-- LCD_BarGraph_Draw( Value , 3 , 1 , 16 , 255 , Blocks)
-- The Value of the BARgraph (0 to Range).
-- If Range = 100 and Value is 50, then half of the BARgraph will be filled in.
-- Value MUST be a WORD sized variable.
-- LCD Row to place the BARgraph (1 to 4)
-- can be either a constant or a variable.
-- LCD Column to place the BARgraph (0 to LCDsize - 1)
-- LCDsize is the number of Chars in 1 line of the LCD, for "4x16" it's 16
-- Width of the BARgraph in charaters. (1 to LCDsize)
-- Range is the "full-scale" range of the BARgraph (0 to 32768)
-- MUST be a constant. Variables will not work here.
-- Style selects which Style will be used for the BARgraph (lines, boxed, blocks)
-- Define styles
Const byte Lines = 1
Const byte Boxes = 2
Const byte Blocks = 3
-- Define Bar numbers
Const byte Boarder = 3
Const byte OneBar = 2
Const byte TwoBars = 1
Const byte ThreeBars = 0
-- 4X20 LCD
-- Const Byte Row[5] = {0x80,0x80,0xC0,0x94,0xD4}
-- If 4X16 LCD is used, comment the above line
-- and uncomment the following line...
Const Byte Row[5] = {0x80,0x80,0xC0,0x90,0xD0}
-- Global Variables here
Var byte BAR_Style, BAR_Loop
Var word Remainder
Var sdword BAR_Temp
Procedure CharSetLines is
Var byte Fvar
_lcd_write_command(0x40) -- Go to CGRAM location 64
while (Fvar < 1) | (Fvar < 8) loop
lcd_write_char(0x15) -- Custom char 0 - 3 lines |||
Fvar = Fvar + 1
end loop
_lcd_write_command(0x48) -- Go to CGRAM location 72
while (Fvar < 1) | (Fvar < 6) loop
lcd_write_char(0x14) -- Custom char 1 - 2 lines ||:
Fvar = Fvar + 1
end loop
-- lcd_write_char(0x15)
_lcd_write_command(0x50) -- Go to CGRAM location 80
lcd_write_char(0x10) -- Custom char 2 - 1 line |::
Fvar = Fvar + 1
end loop
End procedure
Procedure CharSetBoxes is
Var byte Fvar
lcd_write_char(0x1F)
lcd_write_char(0x15) -- Custom char 0 - 3 lines III
Fvar = Fvar + 1
end loop
lcd_write_char(0x1D)
lcd_write_char(0x14) -- Custom char 1 - 2 lines II:
Fvar = Fvar + 1
end loop
Fvar = Fvar + 1
end loop
End procedure
Procedure CharSetBlocks is
Var byte Fvar
lcd_write_char(0x1F) -- Custom char 0 - 3 block |||
Fvar = Fvar + 1
end loop
lcd_write_char(0x1C) -- Custom char 1 - 2 lblock ||:
Fvar = Fvar + 1
end loop
Fvar = Fvar + 1
end loop
End procedure
Procedure CharSetDots is
Var byte Fvar
_lcd_write_command(0x58) -- Go to CGRAM location 88
lcd_write_char(0x15) -- Draw a three dots . . .
lcd_write_char(0x00)
Fvar = Fvar + 1
end loop
End procedure
Procedure Char_Set(byte in Style) is
BAR_Style = Style -- Remeber last used CharSet
if Style == 1 then -- Load new custom chars if style is changed
CharSetLines
elsif
Style == 2 then
CharSetBoxes
elsif
Style == 3 then
CharSetBlocks
Else
CharSetLines
End if
End procedure
Procedure LCD_BarGraph_Init is
-- Bar graph is initialized to lines at start up
BAR_Style = Lines -- 1 = Lines, 2 = Boxed, 3 = Blocks
Char_Set(BAR_Style) -- Load custom chars when PIC is 1st powered on
CharSetDots -- Load boarder dots
End procedure
Procedure Calculate(Word in BAR_Value,
Byte in BAR_Width,
Word in BAR_Range) is
Remainder = BAR_Temp % BAR_Range
BAR_Temp = BAR_Temp / BAR_Range
End procedure
Procedure LCD_BarGraph_Draw(Word in BAR_Value,
Byte in BAR_Row,
Byte in BAR_Col,
Byte in BAR_Width,
Word in BAR_Range,
Byte in Style) is
Var Word Limit
If (BAR_Width == 0) Then -- If BAR_Width = 0, do nothing
return
End If
If Style != BAR_Style Then -- If style changed, the load the
Char_Set(Style) -- new style to LCD CGRAM....
End If
BAR_Temp = Row[BAR_Row] -- Define at which row the bar is
_lcd_write_command(BAR_Temp + (BAR_Col - 1)) -- Move cursor to bar grpah
Calculate(BAR_Value, BAR_Width, BAR_Range) -- Make complicated calculations
While (BAR_Loop <1) | (Bar_Loop < (BAR_Width - 1)) loop
lcd_write_char(ThreeBars) -- Send 3 bars
End If
lcd_write_char(Boarder) -- Clear to end of bar width
End If
If BAR_Temp == BAR_Loop Then
Limit = Limit / 10
lcd_write_char(TwoBars) -- Send 2 bars
Else
Limit = Limit / 10
lcd_write_char(OneBar) -- Send 1 bar
Else
lcd_write_char(Boarder) -- No bars sent
End If
End If
End If
BAR_Loop = BAR_Loop + 1
end loop
End procedure
Maybe here is a smart guy, who can say me what I'm doing wrong?😕
O.K, here the new version.Now it works, but there is some unexpected behaviour.
First: the bar is shown on the wrong line.
Second: Although there is no command to change the column "lcd_cursor_position(BAR_Row, BAR_Col)" here , it does change it.Actually it is not a fault, it must change the column to work, but I don't understand how it happens.
-- How to use:
-- LCD_BarGraph_Init -- Init LCD bar graph
-- LCD_BarGraph_Draw( Value , 1 , 0 , 16 , 255 , Lines )
-- LCD_BarGraph_Draw( Value , 2 , 0 , 16 , 255 , Boxes )
-- LCD_BarGraph_Draw( Value , 3 , 0 , 16 , 255 , Blocks)
-- Define styles
-- Const byte Boarder = 3
-- Const byte OneBar = 2
-- Const byte TwoBars = 1
-- Const byte ThreeBars = 0
-- 4X20 LCD
-- Const Byte Row[5] = {0x80,0x80,0xC0,0x90,0xD0}
Var byte BAR_Style
Var word Remainder
Var sdword BAR_Temp = 0
for 7 loop
end loop
for 5 loop
end loop
for 5 loop
end loop
End procedure
for 5 loop
end loop
lcd_write_char(0x1C) --(0x1D)
for 5 loop
end loop
for 5 loop
end loop
End procedure
for 7 loop
end loop
for 5 loop
end loop
for 5 loop
end loop
End procedure
for 5 loop
end loop
End procedure
CharSetLines
elsif
Style == 2 then
CharSetBoxes
elsif
Style == 3 then
CharSetBlocks
Else
CharSetLines
End if
End procedure
End procedure
Byte in BAR_Row,
Byte in BAR_Col,
Byte in BAR_Width,
Word in BAR_Range,
Byte in Style) is
Var Word Limit
Var Byte BAR_Loop = 0
return
End If
End If
lcd_cursor_position(BAR_Row, BAR_Col) -- Init cursor to bar graph start
BAR_Temp = BAR_Row -- Define at which row the bar is
-- lcd_cursor_position(BAR_Temp, (BAR_Col + BAR_Temp)) -- Move cursor to new position
lcd_write_char(0) -- Send 3 bars
End If
lcd_write_char(3) -- Clear to end of bar width
End If
Limit = Limit / 10
lcd_write_char(1) -- Send 2 bars
Else
Limit = Limit / 10
lcd_write_char(2) -- Send 1 bar
Else
lcd_write_char(3) -- No bars sent
End If
End If
End If
end loop
End procedure
