LCD Backlight to the Max
Has anyone experimented with using multiple compact fluoros and a flat white diffuser to illuminate an lcd. I am thinking along the lines of CRT here. I have a crt projector, and an extra set of 8" lenses.
CRT's are relatively not that bright. My thought is if you could generate an even very bright back light using a flat white back panel (diffuser) with four surrounding 6500k 23 watt cfl's. then use a frenzel to focus the light then put a 8" crt lense infront of the panel very close like a crt. CFL's are approx 1500 lumens each. 6000 total * .50 * .79 * .15 = 337.5 Lumens at the lense. (that is just an estimation, of losses through the components.)
I dunno if it would work, but I think it might. Maybe even upping the wattage of the bulbs. Flourex 65 watters put out alot of lumens (8000 or so).
I was just wondering if anyone has experimented with such a set up, so I can gain some knowledge prior to wasting my time...lol. What will my design challenges be?
JR
Ive got a 3M 1810 @ 2500 lumens. Its cool and quiet as advertised and does work with my Benq 531 panel. The problem is its not bright enough. I got the same idea as the guy in this thread:
Increase the lumens with 3 - 23Watt CF bulbs (150 watt equivalent = 1450 lumens each) in the enclosure. I am using the clip on bulb contraptions with the reflective cone from the hardware store. I figure I can shine the main bulb through the middle with the 3 CFs slightly off angle pointing at the freznel. Kind of a semetric flower pattern. Or maybe point them all at a mirror pointing at the freznel to reduce the beam spread.
Im not sure why people are talking about a point source. wouldnt that make the middle of the 15" LCD brighter than the rest? Dont you want even luminocity across the whole LCD? Wouldnt a white defuser under the fesnels help with this?
Please explain.
I built a light box this weekend, using 3 20watt 65k cfl's I put them in a box just larger than they are. I mounted a mirror behind the lamps as the back of the box. I also dissasembeld the lamps and removed the ballasts to make the box more compact. I originally figured there is maybe 50% usable light.
I tested it on my ps1/crt lense projector I am building. There are a couple of issues.
1. light loss in the box. Inherently light coming from a CFL is not directional very "scattered" if you will. I remeber on another board dicusion about a light source ability to penatrate and hid's have a very intense point source, where as cfl's iluminate a large area of phosphor in a tube. So maybe there is 30-40% of the light coming out of the box and the rest is wasted light it is extremely scattered.
2. Heat is a another issue the box gets pretty hot. I used a light diffuser from an old laptop LCD and I was afraid it was going to melt. I don't think it can be as close to the LCD as it needs to be to be effective in this configuration.
My results....Well the jury is still out, I am gonna test a few more configurations I was able to get a relatively low level through the LCD. It may be a watchable picture on a screen, but needs to be about twice as bright. I would say maybe 50-100 lumens @ 48" 150-250 is my goal.
I am gonna try two cfl's and see if I can improve the efficiency of the light box. Maybe use reflectors in a batwing config instead of the mirror to get more light where I want it.
CFs are difuse light but you already know how to solve that problem: Fresnels.
Buy a mirror from a glass shop and get a glass cutter and silicone. Make a mirror box (angled walls) for each CF and put a fresnel on top to focus all the light coming out of the box. Repeat several times. :smash:
Make a box that angles all the focused light on a concave "vanity" type mirror. It doesnt have to be optically precise it is collecting several light sources and aligning the light to a point. use a fresnel to open the point to a plane of colinear light.
I am setting up about 6000 lumens in this manner with about 100Watts power used. I can add more lights if i wish. Also the light temp is right and its not dangerous like metal halide - no chance of fire, exploding bulb or UV burn. 😎
I have a serious problem with the idea of high current draw in my house. Firing up a MH could make the wall wiring hot enough to catch fire. Im in an old building with aluminum wire. No chance im using MH. :hot: I dont want to pay that kind of electricity bill either.
The only problem with this setup is that its bigger than a one bulb setup.
This should help you get more useful light out of your setup:
http://products3.3m.com/catalog/us/...ikuiti_3_0/command_AbcPageHandler/output_html
Note that a metalic reflector will not randomise the polarisation so those setups cant take advantage of the film. their plastic reflector film (>98% reflectivity )however will work as will any mylar I assume.
You could use an easily workable material to shape a parabola and coat the inside with the reflector film. This would be smokin efficient with CF bulbs but just smoke with MH bulbs :hot:
