LC line level X-over
Hi all
Anyone using line level LC X-overs instead of
active X-overs ? How do you like them ?
Have tried making various op-amp and valve active filters,
but they are not for me so far.
I am using 2. order RC filters at the moment,
but want to go 3. order.
Rescaled to 600-700 ohms the inductors get pretty big.
What type of inductors to use ?
Is there any threads on this allready? :scratch:
Thanks 🙂
Koinichiwa,
Like this?
http://www.marchandelec.com/xm46.htm
I would suspect the reason actually to be simply the fact that most textbook active crossovers do not work with real world drivers, which invariably require equalisation.
It is almost impossible to correctly "activate" commercial loudspeakers using textbook active crossovers. You need to design the active crossover specifically tailored to the Speaker you are using or add an equaliser ahead of the active crossover.
Or you could just buy a good digital crossover and use that, they usually include equalisation.
Sayonara
Re: Re: Re: LC line level X-over
Koinichiwa,
planet10 said:
Thanx for pointing that out T.
Where would one go looking for chokes for a DIY version of this beast?
dave
Hammond has pretty large value chokes in the program, otherwise it's the trusty old winding machine. Can be made from a simple sewing machine motor, speed pedal, clamping mechanism for bobbins and a resettable counter for turns....
Sayonara
Hi Kuei Yang Wang
Kuei Yang Wang said:
Yes, like that 🙂
But DIY , of course
Yes, but still I like the passive line-level RC crossovers I use at the moment better than the active X-overs I've tried.
Haven't used a commercial loudspeaker since '85 or something,
I'm still having problems making good crossovers 😉
That would probably be ideal, don't have that kind of money,tho
:bawling:
Hmm, probably the best way to do it, but what kind of core?
150-200 mH would be far to big if air-cored. :scratch:
cheers
Koinichiwa,
slowmotion said:
Yes, like that 🙂
But DIY , of course
Last time I looked Marchand WAS DIY Stuff, if in a kit....
Slopes are much lower order on that if you implemented 4th order filters active....
:bawling:
Well, while it has yet to materialise from Vapour ware into reality, Behringer in Germany will soon have a suitable unit:
http://www.behringer.com/02_products/prodindex.cfm?id=DCX2496&lang=ger
US retail is set at $ 440. Okay, not as cheap as some handwound chokes and a handfull of capacitors, but still hardly expensive. Similarly priced units with similar specs are available from dbx (Driverack) and LEM, to NAIM those that immediatly come to mind.
I would say Mu-Metal. But it is not easy to make chokes that have a defined inductance on these and they cost a lot of money. Not for the fainthearted. Ferrite Potcores are easier to use and have a better linearity but tend to sound not as good subjectively as a suitably designed choke with Mu-Metal or Permalloy (at least in RIAA EQ circuits I found that the case).
Sayonara
Hi
Tried 2nd and 3rd order active, liked 3rd better than 2nd in my room.
Very subjective, I know.
Well, while it has yet to materialise from Vapour ware into reality, Behringer in Germany will soon have a suitable unit: http://www.behringer.com/02_product...CX2496?=ger
Thanks for the tip , I'll go have a look 🙂
Ok , " a lot of money" is out,😉 , I'll have a look at ferrite, then.
cheers
