Latest version of WinIsd for Windows 10 ?
Hi GM, I hope you are well.😉
Do you remember the Eminence Delta Pro 18 A sealed cabinet subwoofer with speaker?
Well, I'm playing a bit to see if I pass it to BR, I was in contact with Jerry Mc Nutt a while ago (before COVID) and between some email exchanges, his conclusion was that speaker (now discontinued) was not designed for sealed cabinets, something I already knew, but since EBP was right on the edge, I decided to try it.....easier to model, and less chance of errors.
With DSP I have achieved a clean, dry and fast bass, and "level", (this last is a way of saying, flat, what is said flat, it is not, that is obvious) let's say extended to 20 Hz, but I thought that maybe I miss some reverb from my vintage JBL 14", that's kind of hard to understand if you don't hear it in person...I'm messing around with WIN Isd a bit...
Cheers !
Cheers !
Greets!
Doing OK, all things considered and hope all's well at your end.
Vaguely.
Understood! Well done vented gives it that 'toe tappen' sound of a live event.
I used Win Alpha Pro for years on Win 2k, 7 pro and it was easy to use and 'bulletproof'.
Good luck with it!
OK, when you feel like accompanying the music with your feet, which is not the same as "walking". Mine was a bad example. Perhaps influenced by Johnnie, who is usually present in blues listening..... 😊
https://en.wikipedia.org/wiki/Bassline#Walking_bass
Reactions: GM
