Laser Pickup´s M52103FP RF-Amp instead of older CX20109 RF-Amp
Hello to all,
Could I use the M52103FP RF-Amp (mounted directly on KSS-240A lasers and probably many others) instead of the older CX20109 RF-Amp,
The aim is to mount the M52103FP directly under the laser ( KSS-123A ) in order to shorten the current signal paths and have a probably cleaner RF-Signal.
It would be not a total replacement, because the RF-signal would be then fed into pin No.2 of CX20109 to create the final EFM Signal.
Is this possible?
All the best,
Salar
From Mitsubishi's M52103FP (OPIC include buffer OP-Amps) there isn't datasheet online. But there are a lot of other OPIC's (see attachement).
Perhaps one of this types is suited for your requirement.
