Laser Engraving & CNC Milling Hammond boxes
The Hammond 1455 series of enclosures are popular for many projects.
The black versions come with 0.060" black anodized panels.
I have seen a few CNC/laser machines listed in Kickstarter or Indiegogo campaigns that might be suitable to machine and engrave these panels.
Perhaps someone has experience with one of these machines or alternatively knows a low cost service provider that could finish these panels.
I have used Front Panel Express. They are fine for a few panels provided that you are OK with 100% milled text. I generally run 25 to 100 panels, so this is very expensive.
Al
I use my homemade CNC for engraving and cutting aluminum all the time. engraving is done with a 60 degree V bit (v-carved). cutting holes is done with a straight endmill; the size of the endmill depending on the size of the hole but usually a 1/16" or 1/8" endmill is used. the results are spectacular.
