Hi
I need 5 pairs of RCA plugs, capable of accepting Belden 1694A video coax – “nominal” OD = 7 mm (0.274 inches).
I’ll be using them in two active systems, one with SE amps, the other likely the Aksa Nirvana.
Cable specs fyi here:
http://bwccat.belden.com/ecat/jsp/I...efined&P4=undefined&P5=undefined&P6=undefined
What are the best options? (How are they connected, eg soldered); and
Is the strain relief effective?
Any other comments . .
I also need a set of connectors, for the same cable for video.
I haven’t bought the DVD or projector yet, but I’m told HDMI is the best.
Not Analogue, but if you also have an opinion, what connectors do you recommend for 7 mm cable & HDMI?
Thanks!
Thanks!
Do you have the cable already?
If not I would find a local 'home manufacturer' with the experience and kit (eg crimps) to do the job reliably.
I get my cables from http://www.bluejeanscable.com/ or from eBay.
1694A is very stiff. Unless you have very long runs it is probably overkill. But then I don't know how extreme your system is.
Hi jimbo
I’ve accepted an offer from a friend to buy.
I may try to find a local 'home manufacturer' with experience & kit to do the job reliably, if my attempts to join don’t work.
I’ll still need to select a good plug.
Yes, I’ve heard Blue Jeans are very good, but $/ m I think it’d come out more $.
My friend had acknowledged that 1694A is very stiff. The min. radius is 70 mm (2.75 inches). Should just work . .
My two systems are probably somewhat “extreme” – SL’s Phoenix with Aksa Nirvana, and another active system - SE tube amps + horns.
BTW:
I believe Canare are possibly the best way to go . . but
. . I can’t justify the $$ cost of their crimping tool
A soldering option or generic crimping is what I’m after.
BTW:
