large format lens image circle Help
HI,
I have a friend who is selling a lens that is made for large format photograply. I did some research and found the image circle for this lens stated as 750mm at 1:1 reproduction ratio. The lens has a FL of 450mm.
Can someone explain what this means please? And in short will it work to focus my 17 inch lcd corner to corner?
Its maximum aperture is stated as f9. Will this mean it will be too dark? I believe its 106mm in diameter.
45-46 degree coverage.
probably won't work well, I do have some projection lenses, with minor mods ( I can give you the details) will work quite nicely, I'd be interested in a trade of one + some $$$ in exchange for that proces lens, if you're interested. I can be emailed at erie at shelbyvilledesign dot com
