Laptop to DAC interface
I own a dac which will accept either optical or coaxial inputs and after a search on this forum and google I am more confused than ever.
I wish to send audio from my aging Toshiba laptop with windows XP, to my
external dac ( as mentioned optical or coax inputs only ) The laptop provides usb out and I thought that all I needed was a usb to digital coaxial cable. It appears though that this ' cable ' does not exist.
So can I diy something that will work ?
Yes, it is a great product and does the job pretty well. Drivers work flawless but only under MSWin. Does not work for Linux.
It uses a-synchronous data transfer which is the only proper way to have low jitter.
You can get several pcm 270x/290x based variations on ebay for like 30-something bucks, shipping included. Or if you settle with optical output another one at a fair price could be Behringer UCA-202 (pcm 2906 based plus some opamp, IIRC).
As Pjotr said, don't waste more money on it.
