Hello,
I need a laboratory audio amplifier 10-30W who can deliver the same square signal between 10Hz and 100KHz without deformation IN/OUT. Unsuccessful so far and I already made and test 3 different types.
Will be possible to achieve what I need? Maybe is not possible ? Anyone can suggest a schema which can work? Thanks for any answer !
For a good 100kHz square wave, you would need 1MHz bandwidth at full power.
Is this for use at 8 ohms? Are you sure that's what you want?
Krohn-Hite Widebnd Power Amplifiers
Yes is for 8 ohms, about specifications, I'm only interested to have a perfect square wave on output from 10Hz to 70KHz (better 100KHz) at mini 10W-30W
Winfield Hill's amp does that, out to several MHz, perfect 100kHz square wave.
But such an amp is NOT a 'simple' audio amp, there is considerable difficulty and complexity to get that type of performance.
Only diy if you are a very experienced electrical engineering type of guy. Are you?
Jan
Jan
Will there be a linear (sinusoidal) signal, or only square-wave pulses?
2003 can be modified for your specification.
https://aliexpress.ru/item/32819329...earchweb0_0,searchweb201602_,searchweb201603_
will be use with sinusoidal signal but most of the time with square wave. I'm happy if I have 10Hz to 50KHz. I have test Hiraga, Aleph and other amplifiers but is not working how I need. Winfield Hill's is not what I was thinking when I decided to diy a measure amplifier.
General idea (I don’t know if it’s suitable or not)))
Some refinement required - Fall Front Damage
Усилитель JLH (John Linsley-Hood)
- laboratory audio amplifier
