LA6517 op-amp Upgrade?
where is it used in the CDP? is it used in the motor control circuitry or audio circuitry?
the datasheet suggests it's key attribute is high current output (for a DIP IC).
it's quite slow and likely not exceptional at noise, distortion and other audio relevant specs, so i suspect it's not used in the audio circuits.
