I'm searching for any info regarding this reciver from the 1960's its all tubes!
Kenwood KW-40.
Thanks!
Kenwood KW-40.
Thanks!
Kenwood KW-40
I am also looking for information, specifically a schematic, of this unit. The one I have is actually a Trio W-40 but I believe it is the same. It has a problem of overheating a resistor in the power supply.
If I come across anything, I'll send you a note and I would appreciate the same from you.
KENWOOD
Not much of help I know but for what it is worth:
These companies are one and the same.
Increase the wattage of those Rs in the PSU and it will last for
ever.
Cheers,😉
ever.
Cheers,😉
I have tried all kinds of search engines looking for a "Kenwood" maybe I should try "TRIO"
Thanks for that tip!
KENWOOD
Well...I tried that but to no avail.
Also I looked through Sams' Photofacts library,no hits either.
It's just a wild guess but the following could happen due ageing:
1.A cap in the PSU may have dried up overloading that resistor.
2.The resistor itself has changed its' value.
Cheers,😉
Cheers,😉
