I posted to see if someone can give some advise to me.
I have my KRELL KSA100S for over 3 years now. Recently when I switch it on, the relays would not be activated. Instead, the amp will turn off by itself after 1 to 2 seconds ( the front panel lamps all turned off).
Any one experienced this before? Should I send back to repair?
Unless you like big, expensive paperweights masquerading as amplifiers sitting in your front room.😉Should I send back to repair?
