Krell FPB 300CX transistors emitter resistors
My name is Jose Oliveira and I live in Portugal.
I have plans to change the transistor emitter ceramic resistors on the output board of my Krell 300CX, replacing them with Mundorf MOX 5W resistors.
My problem is that, in some of the transistors, the Krell amp is using 0.2ohm resistors and Mundorf MOX does not have 0.2ohm but only 0.22ohm on the list.
I would like to have your opinion if, in case I do it, you think I can face problems or not.
Anyone with experience on refurbish of Krell FPB amps?
I replaced all the electrolitic caps and all IC´s with very good impact, is there anything else anyone suggest I should try ?
Thank you very much in advance for your time and help.
Kind regards ...... JOliveira
Hi josliver,
I have just seen your post, and even if it is from about 3 years ago, I would like to know if you have solved about the emitter resistors. If you have yet that amplifier....
I have the same amplifier, and I would also to know what ICs have you replaced.
