Klipsch Promedia 2.1 repair help
I have a Klipsch promedia system that I want to get working again. The problem is the left channel amplifier output is stuck to the +25V supply voltage...unfortunately it took out one of the satellite speakers...
I found schematics here:
Klipsch Promedia V2.1 Amplifier Repair
I've tested all transistors out of circuit, all are good...zeners test good, ESR on the EL caps is fine... I've retouched all (i think) of the solder joints...
I'm stumped...what else can I check?
