Got this amp today opened it up and found blown caps. was wondering what would cause this to happen only one of the big caps vented. the two smaller caps are bulged out.
Joined 2006
Are there any other issues with the amp?
This amp is two ohm stable if the amp was driving less than a two ohm load, this may have shortened the lifespan of these caps.
I see this from time to time and if there are no other issues, replacing the caps should take care of the problem.
This is a common problem. Replacing the outputs and caps should fix the amp. You can replace all the outputs and filter caps, but I don't think it's necesssary.
Again, the failure may be due to the amp being worked too hard.
alright do you know a good source for these parts? I got this amp with a lot of others from a pawn shop as they had been returned as broken so i have no idea the past of this amp but i think your right just someone who didnt know what they was doing probly had the gains completely up
Here is a link for the IXTQ36N30P's. You may be able to buy them from Allied or Digikey.
IXTQ36N30P IXYS | Mouser
The caps can be replaced with anyting with the same value and same footprint, maybe Nichicon or Vishay.
Or someone else on this forum may be able to recommend a good source. If you can find a spare parts board that would work.
2200UF 25V 105 degree for the filter caps and 10UF 200V non polarized for the caps near the output inductors.
alright thanks alot i appreciate it ill get the parts orderedand installed and hopefully have no more issues if im lucky enough
My bad! I stand correctly, I thought that didn't sound right as I typed it. Too many irons in the fire!
The following ebay auction has something close. I purchased 10 of them from this seller but never used them so I don't know if they're good quality.
201299790746
201299790746
thanks Perry. I just noticed actually a post from back in 2012 you had put part number ef2106 from digikey i was thinking maybe of just doing that also
I use those in amps where there is enough space but I don't think they will fit in the kicker amp. If they will fit, the film caps should work. I know that they're good quality caps.
would you happed to know the dimension of the 820uf 160v cap that is in these amps i dont have anything to measure with at the moment
Update on this amp. found the NP caps on a parts amp I had in the bin and I ordered the other caps and outputs from mouser got them installed and amp is working. Thanks Perry and PapaZBill for the help.
I let the amp idle for a couple hours and i check it and the amp is warm and its drawing 5.18 amps. i opened the top cover and the output inductor is very hot too hot to touch for a second and almost all big caps in the amp are warm
- General Interest
- Car Audio
- Kicker ZX1500.1
