I think its blown. It won't play any music except when i touch the speaker tensils it starts to play but then stops. Also does anyone use these old solos? i got it from a yard sale for $5. I got it to go with my other old kicker equipment.
Sounds like one of the leads is loose/broken.
Anyway, the published specs I have look pretty good if they're reasonably accurate:
Model S12c-4
Nominal Impedance, ohms 4
SPL 1W/1M 88.28
Displacement, cc 1953.33
Displacement, Cu In 119.2
Hole cutout, in dia 11 1/8
Mounting Depth, in 5 5/8
Revc 3.365
VC Inductance, mH 0.606
Sd, SqM 0.0511
BL 12.243
Vas, Liters 212.5253
Vas, Cu Ft 7.50526
Mms, gms 128.089
Fs 18.575
Qms 9.338
Qes 0.336
Qts 0.324
Pmax, watts 600
Xmax, mm 8.51
GM
Model S12c-4
SPL 1W/1M 88.28
Revc 3.365
Sd, SqM 0.0511
BL 12.243
Vas, Cu Ft 7.50526
Mms, gms 128.089
Fs 18.575
Qms 9.338
Qes 0.336
Qts 0.324
Pmax, watts 600
Xmax, mm 8.51
GM
