Kicker IX405d
I have a Kicker Ix405d on the bench with blown power supplies on the class d side and the ab side.
The class D outputs are all blown too.
The z44n's are physically damaged.
I removed all the damaged transistors and the amp powers on.
I noticed there's zero resistance between the z44 source and drain pads on both power supply sections, is this how it should be before I replace with new z44's?
Thank you
