mnhiphop101 Member Joined 2011 2019-11-20 5:05 am #1 2019-11-20 5:05 am #1 when I apply power without the remote i get feedback from the speaker. when I apply the remote it goes away. PapaZBill Member Joined 2013 2019-11-20 4:18 pm #2 2019-11-20 4:18 pm #2 Does this occur when the input is removed? Are you using high or low level inputs? Check the RCA cables and terminal on the amp. The cables may be bad or the terminal is damaged. You must log in or register to reply here.
