KGND-52100 amplifier
I've got a KGND-52100 amplifier I'd like to sell. Here's the specs for it.
KGND-52100 Specifications
Power output @ 0.1% THD: 4 ohms: 1000W
Power output @ 10% THD: 4 ohms: 1200W
THD: 0.08%
S/N ratio @ rated power: 90dB
Input sensitivity @ 100Hz - low level: 190mV
Input sensitivity @ 100Hz - high level: 4.2V
Input impedance: 22k ohms
Variable Low Pass Crossover Freq.: 50-100Hz
Bass EQ @25 Hz: 5db
Efficiency: 86%
Weight: 13.5 kg
Dimensions W x H x D inches: 12 x 12 x 4.5"
Dimensions W x H x D millimeter: 305 x 305 x 115mm
AC Voltage: 115/ 230
I bought it in new from acoustic-visions a couple years ago(first part of 2003). I still have the original box it came in, it's what I'll use to ship it in.
If it matters I'm planning to buy a pro amp and building an LT circuit for my Tumult and this amp just doesn't have the power for what I want.
I'd like to get $275 plus whatever shipping costs are. I work in Tempe, Az so if someone is local and wants to pick it up that's fine by me.
Thanks for looking,
Brad
