Kenwood Sovereign power chips
Probably these; https://www.semicon.sanken-ele.co.jp/sk_content/std01n_ds_en.pdf
or the higher power version; http://www.semicon.sanken-ele.co.jp/sk_content/std03n_ds_en.pdf
TRAIT stands for Thermally Reactive Advanced Instantaneous Transistor. This means that the thermocouple necessary to compensate for temperature effects in power transistors is housed inside the transistor instead of the traditional place on the heatsink. This minimizes the time difference between actual temperature of the transistor and measured temperature on the heatsink. This improves the sound quality of the amplified signal.
TRAIT transistors have 5 pins instead of the normal 3 (Base, Collector, Emitter or Gate, Source, Drain for MOSFET's) TRAIT transistors, manufactured by Sanken Electronics, were used in the mid 1990s for the first time in Kenwood amplifiers. TRAIT is called K-Stat in the USA.
Sanken site: SANKEN ELECTRIC : Relocation Notice
I think yours may be the STD01N/P or the STD03N/P
If your N3Y has a transistor marked P3Y near to it, then it's likely that you need an STD03N, which would probably be the Kenwood equivalent.
Alternatively SAP15P/M
(Datasheet) SAP15 pdf - Darlington transistors with built-in temperature compensation diodes f Darlington transistors
