KEF Blade DIY effort now a more affordable venture
So anyone interested in tackling a DIY effort using the Q150 drivers, they’re on sale again at a little more than 40% off suggested retail……I already have the white pair with the raw aluminum colored Uni Q but I just ordered another pair of the Walnut version for another variation…..a hybrid active 3 way with powered bass module and 2 8” woofers
Would you please post where you bought the drivers?
Thanks.
Bought the complete speakers as the crossover for the Uni Q is pretty good……..I don’t listen on axis so the mildly hot top end smooths right out after 15 degrees.
I also found value with the whole box as I don’t know where you’d get the trim rings otherwise…..I’ve seen the raw drivers for $120 each…….so add in the XO, boxes, hardware and trim…..at $350 still high value.
Reactions: Tony D.
