I've got a pair of KEF 103/4 on a garage sale with bass drivers shot.
Surrounds are all rotten and have to be replaced, for sure. I have tested
all 4 drivers, and only one voice coil is OK, others are open, pressumably shot.
I would like to get any data on these drivers. KEF model B160 Sp1302, 8 Ohm.
Those are fitted two per cabinet and connected with a steel rod.
I guess I should plan for worse case scenario, just in case and would need
complete recone with new coil and spider as well as surrounds.
What about foam dustcap? it's not traditional style, it's more like donate shape
made of the same foam material as surround.
What are my options? I would like to do this myself, but parts might be a problem.
where can I get those? I have never fix drivers before, just build some speakers and crossovers.
Refoaming looks easy but complete recone is unknown to me.
Any recommendation from you guys?
What are the opinions about importance of the donate-dustcap where the rod is passing through?
Thanks in advance.
Igor
Thanks in advance.
Igor
Hi Igor, I would suggest that you contact KEF for replacement woofers. If the coils as well as the foam surrounds are gone then they are your only hope for replacements.
The centre "doughnut" dustcap is actually a rolling seal because of the need to connect the two drivers with the force cancelling rod. You will not find aftermarket replacements for these.
Good luck
Andrew
Good luck
Andrew
Andrew,
Well, KEF doesn't have a replacements for some time now.
I guess complete recone is in order.
Voice Coils on all 4 drivers look OK and Cone is moveng, albeit with some scratching noise.
Does that mean VC former is shot and not the coil?
Also, the only working driver sounds bad, but with no surrounds and rolling seal (as you said) doesn't mean much, I guess.
What is that "rolling seal"? Is it necessary for the "sound"?
Does anyone know for sure?
Igor
Igor
Igor, if the voice coils are in-tact, ie measuring somewhere around 4-6 ohms resistance, then they should be OK. The scratching sound is caused by the coil rubbing against the top plate because of the rotted sourround no longer keeping the coil centered in the gap.
even if you find a repair kit for the surrounds you are still left with the problem of the rolling seal. I do not think you will find a replacement for this.
The only other solution is to forget about the force cancelling rod and just use a regualr dustcap. The force cancelling rod is used to reduce box vibration and clean up the sound. Without it the speaker will still work, though there will be more box colouration to the sound. Make sure if you do this that you adequately fasten the drivers into the box.
The driver parameters are critical to the performance. Not only do they determine the box tuning, but also the impedance seen by the xover. The xover is very complex, and the driver impedance is heavily conjugated in order for the xover to work correctly. If you change the driver for a substitute you will find that the xover response and impedance may go haywire!
All the best
Andrew
All the best
Andrew
Andrew,
Thanks for your help.
I assume, rolling seal is there instead a dutcap, to prevent dust geting between the rood and a cone. Omitting it would be a bad idea.
Igor
Igor
Igor, you are right about the rolling dustcap acting as a seal. It does this for two reasons. One is as you say to keep dirt out of the gap, but the other is to seal of the air leakage path. Coupled cavities are quite sensitive to leaks between the two cavities.
regards
Andrew
regards
Andrew
KEF 103.4 Drivers repair
The surrounds are gone on my 103.4s.
The bits are falling out.
An obvious question to some, but how do I get into the cabinet to remove the drivers?
Rich
Rich
KEF 103.4 repairs
I got into the cabinet easily, so please ignore my previous post.
I got my AR6 drivers surrounds fixed about 15 years ago. Does anyone know a local repair shop here in Birmingham, UK?
Hi RichG4PCE,
I just got a pair of 103.4 whose surrounds have gone becuase of the age. Would you please shed some light on me how to safely remove the woofer units from the cabinets? I would like to take these units to a local speaker repair shop to get new surrounds.
Thanks a lot!
Thanks a lot!
Allenr,
Very easy. Take out the 8 screws holding the terminal plate at the back of the cabinet. The plate comes away with a little persuasion. Make a note of the wire colours and their connection terminals.
Remove the souns wadding, the top speaker is now accessible, remove the centre screw in the magnet, which holds the force cancelling rod in position.
Turn the cabinet over, remove the spikes and all the Posidrive wood screws, and take out the bottom wood piece. The bottom speaker is upside down, and the connections are soldered. You can either feed the wire connections through from the top, or just cut them close to the speaker and resolder them later when refitting. Again, remove the force cancelling rod screw.
I repaired myself, the inner, smaller seals were rotted too. I got the surrounds in UK, about 30 pounds, 60 dollars. Its not too difficult, if you are patient and precise in repositioning the speaker cone in the centre. It must'nt scrape in the magnet centre!
I can let you know the foam supplier I used, if you need.
Rich
Rich
Thanks a lot pal!
I tried to unscrew the back panel before but did not dare to remove it since I lack the "pursuasion" 🙄
Anyway, I think I might need to send the whole cabinets to a local repairer since I have no experience in soldering...
How are these speakers sound after you restored them? Worth the trouble at all?
You just have to prise the plate gently with a flat screw driver to break the seal. Its not difficult. Then wiggle the plate out, it has the cross over network circuit board fitted to it.
The speakers are lacking in base imo. The mids and highs are excellent.
Perhaps with a separate sub woofer, they would be very good.
I got all the foams, outer and inners from:
speaker-repairs.co.uk
Kef B-160 repair
I own a pair of KEF B 160 woofer, 20 years old, there is a scratching noise when i slightly push the cone in, would that be the cone edge that need to be replaced or also the voice coil /spider
any help would be appreciated
thanks,
thanks,
j
I would guess any scratching is likely to be the voice coil former contacting the magnet in the centre. The outer foams might be deteriorating too, after 20 years. The cone edges shouldn't be touching anything.
Have you actually removed the drivers, to inspect?
Rich
Rich
Kef 103/4 woofers
I have the same problem but my woofers. I have looked for a repair kit (they are some for 8'' woofers though) in USA and could'nt find one. I contacted Kef and they want me to buy new speakers...
My solution... a good subwoofer. I connect the amplifier outputs to the sub and the sub speaker level terminals to the LF input of my Kef 103/4 speakers. Of course, for the HF section I use another line directly from the amplifier to avoid sub crossover for high frequencies.
The sound is as good as it was if not better. And I have the full control over low frequencies.
JiPi
JiPi
JiPi,
I bought some perfect replacement 6" surrounds from speaker-repairs.co.uk
He also has the donut type seals for the woofer centres.
The speakers are fixed now, but they are a little weak on the bass. I have some very old AR-6s with 8" bass units. They are beautiful.
Good Luck
Rich
Good Luck
Rich
Kef 103/4 woofers recconed
HI RichG4PCE,
You're lucky! Were did you find your repair kit for 6'' woofers? Do you think I could get it here in Canada? How much did you pay for? I have only one cone in really bad shape. The others are either in perfect condition or only the doughnout has to be replaced.
Thank you!
JiPi
HI RichG4PCE,
Thank you!
JiPi
RichG4PCE,
Thanks! I checked on the web site you mention and I should be able to get the kit from the USA.
You mention that the bass are not very strong. Is it because of the new kit? Maybe a break-in period is needed. Let me know if the replacement is worth the effort.
Great!
JiPi,
Great!
JiPi,
I have a bit of a worst-case scenario with my B160 bass drivers - all 4 of them. I won a pair of KEF 103.4's at auction and the tweeter and mid are fine however I knew the surrounds of the bass drivers were likely to be shot. I also knew if the last owner had driven them with perished surrounds the bass drivers could be shot.
Worst case scenario in all 4 of the drivers extracted so far - totally open circuit in the drivers and the cone is rubbing stiffly in the VC gap. Two of them had a literal meltdown they were driven so hard - the plastic in the middle of 2 of them completely melted.
I managed to knock the price down for this as the owner had them in a cafe and hadnt tested them for years and I really need another project (lols).
As I got them so cheap - Im happy to tolerate a "close enough" approach. I already have a pair of 104.2's that are close to 90% good, so if these come close to 100% thats fine.
It doesnt seem like I can get a recone kit for these drivers. Sending them to and from KEF (from NZ) isnt an option due to weight.
Anyone know of a potential DIY fairly generic recone kit that could fit these drivers? It seems a shame to replace the drivers entirely as my reluctant 2nd option will be this.
cheers
cheers
Are you sure the tweeters are still good? I've done one pair of these and had to replace the tweeters with replacements no longer available from KEF. I would expect the ferrofluid to be cooked if the woofers are as roasted as you describe. Even if you delete the steel rod you still have force cancellation from the bass drivers facing each other, as far as that bit goes.
- KEF 103/4 Drivers B160, recone
