they will be used in this circuit: http://www.nijnkonijn.nl/machmat/schema/power/se/anp4.gif
there are 3x .39uF per channel.
Thanks again
Thanks again
K40y-9 are very decent PIO caps, at reasonable price, and convenient values and sizes.
If you have more space and money you may want to consider the FT-3 teflons.
A little more info on russian caps:
Audioasylum: TEFLON FT3 CAPACITOR AND OTHER RUSSIAN CAP
DiyAudio: Russian oil caps ?
.39uF is a little inconvenient value. You will probably need to use 2 x .22uF in paralell, unless you can live with the slightly higher cut-off frequency of .22uF (I would).
Svein B.
Svein B.
Probably a bit this but looking at the circuit
http://www.nijnkonijn.nl/machmat/sch...er/se/anp4.gif
Why not use 8 x 0.1uF cross coupled from the driver anodes to the grids so each driver valve feeds both out put valves
This may lower distortion with "real" valves and better balance the currents in the drivers — but perhaps thats not why you have an SE
Keith
Keith
