JX92 VTL enclosure with other unit?
I have read the Daline article – very interesting indeed. Following this, I did some calculations with winISD and came up with the following for the Fostex FE103E:
Cavity volume 3L
Box tuning frequency 50Hz (?)
Line csa and length to suit box dimensions
According to the results given by winISD the Fostex FE108EΣ should be a straight swap.
Any thoughts?
Many thanks,
Lee
This one is slightly different in that the line expands to the mouth, presumably to give it a little horn action. The VTL keeps a constant area line and the original Daline tapers towards the mouth. They all use a similar principle, though of using the chamber as a bandpass filter between driver and line.
Just make sure you don't try tuning below 0.707Fs or your midbass will start to go AWOL. So the enclosure for a 108 ideally doesn't want to go below ~54.5Hz, and preferably not that low. Remember too that the Sigma is a low excusion driver with an Xmax of 0.28mm, which doesn't give much leeway. They can go further, but distortion will rapidly increase.
