Hello!
I like older JVC stuff and would like to get a CD player with the K2 in it.
I have been told that the older xl-z1010 DAC sounds better because of the PCM56P, whereas the xl-z1050 has proprietary JVC chips. Has this been confirmed or is this an isolated opinion that I read?
The other difference I noticed was the xl-z1010 has an optima 4s, and the xl-z1050 has the optima 5s. Which one is better?
The primary role of this device may be a transport, so if one is better than the other, that will help my choice.
Any information is appreciated!
Hi,Hello!
I don't owned the 1010 but I have 1050 and z444 with pcm56 withoptima4 not the 4s one, the sound is much better with 1050 compared with z444, but for the laser optima 4 is much better ( it can read any scratched or dirty disc without skipping). I also owned z411with optima 4s, I guess this unit has the same mechanic and laser with 1010, but this one used MASH dac from Matsushita. I hoped my info would help.
If the "cd/dac list" is accurate, your z444 uses a single PCM56, and therefore has a demultiplexer in analog domain, to separate L/R channels after the dac. This pretty much kills any chance for smoothness in the top end, and probably effects other areas. The 1010 uses individual L/R dac chips, and it should sound better than the 1050(fairly primitive version of MASH 1-bit) if everything else in each unit is equivalently done.
Also, there is no quality difference between the jvc optima 4 & 4s at all. The difference you experience is simply due to precision of alignment & health of mechanics.
Hello,
Sorry for hijack the thread. Do you know where can I find a new Optima5S and procedure to replace the laser pickup.
Hello,
You can transplant from the used xl-v151/251 series.
Do you know the part number for the XL-V151/152 series. If I cannot find the used one, do you know where can I get the new one.
Model Part Cross Reference
sorry for old thread but on that jvc page says optima 4s costs 150 bucks ... maybe you can fit optima s6 not sure if compatibile but 50 bucks on ebay and from expirience also reads schratched cds very well
- Digital Source
- JVC Optima 4s xl-z1010 vs. Optima 5s xl-z1050
