JVC KS-A152 car amp would not turn on, i need schematics or help :)
in power section is C3852 and D1065, output transistors:A1264 and C3181
smps 494: PS494C
c3852/D1065 voltage: 1-2 12V, 2-3 12V
outpur transistor voltage: 0V
tl494 (pin7 - pin12, GND-Vcc) : 0V
situation is same for connected or disconnected REM(12V) !
i can not find where the REM line goes on pcb, i only see connection between rem and 2 point above, and nothing else , here is a image
pcb image
