Hello,
I just replaced the stock bridge rectifier in my Volksamp Aleph 30 with discrete Fairchild Stealth diodes.
The bridge I built is using (4) 50 amp 600V TO-247 diodes, They are not mounted to any type of heat sink.
I get equal voltage out of the power supply pcb, plus and minus 25.2V on both channels.
One channel has 10mv of DC offset, the other channel has minus 200mv DC offset.
I am measuring about 8.9 volts across Z5 on both channels and also about 5.5volts across R11 in both channels.
What could be causing this dc offset difference? I did not measure DC offset before I replaced the bridge. The amplifier was working fine before replacing the bridge.
I am not sure what else to measure?
Any ideas or suggestions would be appreciated.
Best Regards
Kevin
Best Regards
Kevin
so, I traced some voltages at Q4 in both channels and things were equal.
now at R14, in one channel I get -20.5 volts on one side of resistor and -25.2
and in the other channel I get -20.7 volts on one side of the resistor and -25.2 on other
would the -.2v difference be the -200mv I am seeing?
Kevin
Kevin
If it's a factory unit I would email Pass Labs. If it's home built it's just a mismatch of the front end, probably always there if you never checked offset. I think the Wiki has some info on balancing the front end.
Best, Bill
Best, Bill
Bill Fuss said:If it's a factory unit I would email Pass Labs. If it's home built it's just a mismatch of the front end, probably always there if you never checked offset. I think the Wiki has some info on balancing the front end.
Best, Bill
Yes, it is a Volksamp Aleph 30.
I suppose it always had the dc offset discrepency but I am not sure. The side that has -200mv offset runs hot compared to the side that has only 10mv of offset.
The -200mv side runs 4 to 5 degrees farenheit hotter. Is the 200mv dc offset responsible?
Kevin
