just brought new capacitors but i have order the wrong ones. i have a 425 volt witch should of been a 600v.. can i still use the 425 instead of the 600 volt or will it blow my amp up thank you all lee
I would say no, don't use them.
You obviously don't even know what information to provide so that someone could answer your question. This leads me to believe that you don't really know what the heck you are doing, and that you should just stick with the proper parts.
Check the voltage on the supply rail. If it is less than 425v then they are OK. If more, buy the correct parts. You could, if you have enough of them, series parallel them, to give the correct capacity and up to 850volts working.
What is the working voltage? Are they supply filters? Signal coupling? Where do they go in the circuit?
If they're underrated for voltage, they will probably overheat and fail, which may or may not have flow-on effects on other parts of the amp depending on their purpose.
hi all thank you for the fast replys i have got a audio research LS2 preamp i have change the capacitors on the top off the board that i believe are the balance they where 200v but i have replaced them with a 300v but my concern are the capacitors below the balance capacitors at the bottom of the board as they are 600v but i got the wrong capacitor as the value are 425v i have looked at the power supply all i can see is 20-240 vac am i looking at the right volt of the power supply sorry to be a pain and please forgive me if this sound silly but i have only a little knowledge
This appears to be a hybrid tube amp so could have very high voltages.
Are the capacitors electrolytics or film and what value?
If the manual has a diagram locate the power supply and see what voltages are used, the LS22 for example uses +-180v so 425v caps would be ok for example.
Valve gear is dangerous if you are not used to measuring high voltages. I suggest you do not try to measure the power supply voltages.
Alan
Alan
the capacitor are film 425v model dynamicap i cannot see any power rail just a power supply would the voltage rate be on the power supply if not were would i find it all the best chris
On the schematic (circuit diagram ) if you have one.
However as these are film then they are not the PSU (power supply) caps.
Look near the transformer for 2 or more large electrolytic capacitors, these will be the main smoothing capacitors. Check the voltage on them. These will rated a bit more than the maximum but not a great deal as that would be extra expense for the maker.
I would think a rating of 200-250V is probably marked on them.
alan
alan
What ever happened to punctuation?
It makes sentences easier to read when every now and then you throw a period in.
Stick with the proper voltage caps. And be sure you have a better knowledge of electricity than grammar before you go diving into high voltages. Voltages in tube amps can KILL.
Not being mean, just honest😉
thank you all for your infeed i have added the capacitor to my LS2B audio research and is working great looked at the board and found out the voltage is 300v would just like to say a big thank you for all your support and it is much appreciated
I must admit my grammar is not up to scratch however I would appreciate you keep your suggestions to yourself regarding my grammar and on the back of this we cannot all be professionals at everything so please do not cyber bully me on this site
It is not 'cyber bullying' when someone whose native language is, presumably, not English says that your posts are difficult to read because of lack of punctuation. Lack of care in writing may sometimes be a sign of more general lack of care, which has safety implications when high voltages are being used. We like to keep forum members alive.
The non-English speakers on here mostly write very good English - sometimes better than native speakers. We try hard to understand people for whom English is a second or third language, when they are doing their best. We should not need to do that for Brits.
I was not trying to be MEAN, only illustrating the point that working with high voltages take care, knowledge, understanding, and patience.
This is a hobby that can indeed KILL you with ONE careless mistake or lack of judgement. I did phrase it in a cheeky way and if you were offended I do apologize.
The comment about punctuation still stands. People often judge intelligence on ones ability to communicate, it is indeed important.
I am not calling you stupid or incapable, however a bit of care in how you articulate yourself will go a long way towards showing that you are truly serious in your desire to learn.
Again, please take no offense, no "cyberbullying" here, just an old guy who values proper punctuation.🙂
thank youIt is not 'cyber bullying' when someone whose native language is, presumably, not English says that your posts are difficult to read because of lack of punctuation. Lack of care in writing may sometimes be a sign of more general lack of care, which has safety implications when high voltages are being used. We like to keep forum members alive.
sorry. just tired. all my bestI was not trying to be MEAN, only illustrating the point that working with high voltages take care, knowledge, understanding, and patience.
- Design & Build
- Parts
- just brought new capacitors but i have order the wrong ones.
