Hi mates,
i'm interested in Hi-Fi since my early youth. Started with Dual, changed to Denon and bought a Michaelson & Austin M100 + TVP-X combo in the early nineties, because they where the best sounding amps i've ever heard, but always broke. So the friend didn't wanted to keep them.
First i changed parts, fixed connections, changed the burnt, broken pcbs in the M100s and had a good working pair for some years. Then one audio transformer blew up and i had the chance to buy a new pair from the manufacturer of the originals. Now the second one blew up and took the pcb with it.
Another permanent project is a Sherwood S-5500 III and a tuner of that age. Worked like a charm even with nearly non functioning tubes and capacitors. Changed some of the capacitors and used it for some time to drive a pair of Martin Logan CLS, but suddenly it stopped working. Found a bad tube and changed it. Had one channel back, but the other was dead and some deadly current on the chassis. Found a broken heater connection with a cable loose, fixed that and had the voltage on the rca inputs after that.
So there are two projects to work on.
Such happens at parties. 🙂they where the best sounding amps i've ever heard, but always broke.
Welcome to the forum.
Hugo
Looked to me like design feature of Michaelson.Such happens at parties.
Tony Michaelson started as a musician who liked to hear on his recordings, what he played. So he founded Michaelson & Austin with a Kevin Austin. They broke up and Michaelson started Musical Fidelity, which had some problems with reliability too. 😉
Somewhere early in all this trouble Tim de Paravicini stumbled in and fixed and/or delivered new designs and ideas.
So i think you either love it or throw it as far as possible.
