Is there any JLH 10W Amp Protel Simulation file?
I am looking for the protel simulation file.
Thank you for your assistance.
regards,
DKO
regards,
DKO
I have the schematic documents (for protel dxp demo) if that's what you meant.
it is not difficult to set one up in protel dxp either.
to just clarify it a little, it was tailored a little bit to fit my particular set-up (like voltages and resistor / cap values but you can simply adjust all of them if you like). it is for jlh1969.
Hi Millwood,
My amp version is updated JLH.
jlh1969 is OK. I can adjust the detail of components.
I also want to compare both of them by simulation.
Thank you very much.
regards,
DKO
regards,
DKO
here you go.
I included a few files (I have simulated a lot of jlh designs), and those files do contain some extra components (like caps or resistors) used in those simulations so you may want to get rid of them.
at lease they will save you some time reentering those in protel (dxp demo I used).
I have the original jlh, my bjt version of the original jlh (jlh1969), and then the mosfet version using irf devices (just in case).
Hi Millwood,
What is the version of your Protel Software?
I only get the Protel 98.
DKO
DKO
I am using protel dxp (a demo version). Not sure if it is backward compatible to your protel (which sounded like an older version of the same thing).
Hi Millwood,
Sorry. it is not backward comp.
I am going to order the dxp demo.
It takes time to get it from protel.
Best regards,
DKO
Best regards,
DKO
Hi Millwood,
I try to run the simulation of JLH1969 and get the NetList generation
error with Protel DXP.
Would you pls send the whole project file including lib and necessary files to me again?
I only need to simulate 1969 version. If you have the 'JLH Class-A Update' with the Higher Power Version, you can send it to me too.
I want to compare the Original 1969 and Updated Higher Power version.
Best regards
DKO
Best regards
DKO
- JLH 10W Amp - Protel Simulation
