Anyone know of a good replacement for the outputs in this amp ?
The originals or at least what’s in it now are NTP6413ANG. It looks like they have been replaced at some point so not sure if the part number is original
Also what power supply fets does the amp use ? The ones in the amp are all badly burnt
The 540 is rated well below the transistor that was in it. The IRF3710Z may work. The 540 may also work but if the 6413 didn't survive, the 540 probably won't unless that failure was due to a wiring/speaker problem.
