JL Audio 300/4 resistor values needed
Hi all,
I have a 300/4, board rev1 that's had a very poor repair job done. I have everything else squared away except these two resistors. Can anybody help me identify resistor values and/or part numbers for R536(top left) and R508(bottom right). Apparently the reapair facility was out of smd resistors that day. Both installed were 10 Ohm. I'm 99% sure R508 is a 10 Ohm, no clue on the other.
Thanks!
Kevin
Yes the above links were correct parts, size 2010 fits
I am still having distorted audio out of the right front channel though, after replacing power supply FET's with resistors and output FET's with resistors. I'm having trouble choosing a replacement for a 6.8V zener diode on the driver board (which likely went bad when my meter lead shorted pins 2&3 of the driver board)
How do I determine the zener current and reverse current for the replacement part? or do you happen to have a part number handy that will work here?
FIXED!
I replaced the zener diode labeled 6.8Y on the driver board with this part: BZX84B6V8LT1G.
BZX84B6V8LT1G ON Semiconductor | Mouser
I also removed all 4 driver boards and added solder, de-soldered and then re-soldered all surface mounted devices as Perry describes in other posts. During this process I found a 1K resistor on a separate channel that had separated at the end cap, which definitely saves me a future repair on this amp.
