Jean hiraga's super class a build (my first)
textbooks?
You Pays Your Money..... and You Takes Your Chances.....
There are few Hiraga amplifier kits on eBay. Not super cheap, but they will save hunting for small parts. Still need power supply, case, etc....
"Hiraga super 30W class A amplifier kit !"
Hiraga Super 30W Class A Amplifier Kit | eBay
15W Pure Sound Class A Amplifer Kit Hiraga | eBay
Hiraga uses a Current Feedback Amplifier(CFA) circuit topology. There is a very active CFA thread which offers modern CFA designs, PCBs and some hope of expert support. If you can build relationships, you may be able to buy a parts kit.
http://www.diyaudio.com/forums/solid-state/248105-slewmaster-cfa-vs-vfa-rumble.html
If you read article: "NP talk at the California Audio Show 2015" you can get a basic understanding of the Nelson Pass philosophy.
Posted on the First Watt site:
http://www.firstwatt.com/pdf/art_cas_2015.pdf
the.... Swap Meet .... forum often has surprises .... amp kits... unfinished gems ....
I can tell you that the Hiraga 30 Watt amp sounds fantastic! The big thing is that it sounds a bit like a tube amp. That is the key feature I think for this amp. I have built one with boards from Jims Audio(eBay) And then built another one with the boards from Jims Audio with the Kubota regulator on board. I must say this one sounds a lot cleaner than the one with the zeners. So, if you like nice clean sound with a bit of a tube-like sauce, Hiraga is the way to go. I can certainly recommend it!
