Dear All,
I would like to build the SE ampli based on KT88 from Jean Hiraga. I am king of new of the business, but it looks to me that there is something wrong in the design of the power supply:
1) The specs of the rectifier impose a maximum capacitor after the tube of 33uF, while in the design there is a 100uF capacitor.
2) If I simulate the power supply with PSU 2, imposing a load of 200 mA there is no way I get the 375 V required.
I am not an expert, I was wondering if some of you built this amplifier, and if you had problem in the power supply.
Best Regards,
Davide
Best Regards,
Davide
Sorry, that's the schematic: Jean Hiraga 12AX7 Single Ended KT88 Tube Amplifier Schematic
thanks,
Davide
thanks,
Davide
look like is dual mono psu , as there is a 100ma on kt88 and the choke is rated 150ma....
not expert I need to learning how design a tube psu , but 100µ is too big, and small value is better as low peak current ,to lower the ripple better add second filter stage...
the reflect impedence/resistence of trafo is important, to avoid ringind and overshoot and tube want to see a min resistence from trafo (tribute-audio trafo a in 700 ohm range)
the choke resistence play for final voltage...look like is better usa last filter with R to separate the channel and set the rigth B+
here the view of Dht Rob
Google Traduttore
more info here
http://www.freewebs.com/valvewizard/fullwave.html
Google Traduttore
more info here
