Our School has a pair of 250w JBL's that some t***er has bust
- they (apprently) "fell over" onto a drum kit, so a large metal rod has be though the horn tweeter, so i need to know were in the uk (cheshire) i can get it fixed up !!! - with out paying an arm-and-a-leg
thanks daniel
thanks daniel
Is there any sound coming from the high frequency horn? According to jblpro.com, the HF components are:
"1" Pure Titanium Diaphragm Compression
Driver with Patented Diamond Surround", and
"90° x 60° Controlled Directivity Horn Provides Flat Power Response".
The pdf I found here:
http://www.jblpro.com/pub/mi/eon15.pdf
also states:
"HF Driver & Horn:
Diaphragm Diameter: 44 mm (1 3/4 in)
Power Handling: 50 Watts
Dispersion Angle (H x V): 90° x 60°"
Notice the contradiction on the diaphragm size - is it 1" or 1 3/4"?
Anyway, the jblpro site also provided this information:
UK and Eire:
HARMAN PRO UK
Cranbourne House
Cranbourne Road
Potters Bar
En6 3JN
Tel: 01707 668222
Fax: 01707 668010
They should be able to help. If the tweeter still tweets, and the damage is merely cosmetic, perhaps one of your shop teachers could help (?)
dooper
also states:
"HF Driver & Horn:
UK and Eire:
HARMAN PRO UK
Cranbourne House
Cranbourne Road
Potters Bar
En6 3JN
Tel: 01707 668222
Fax: 01707 668010
dooper
thanks - So you think i should go direct to JBL
- and no it doesnt tweet at all!!!
theres a scratch in the metel suround right down the horn and then the wire cover is torn - god knows how deep it went - the drum kit was fairly bent!!
^^somthink like that ^^
(yes - im very sad!!)
![IMGDEAD]](/community/proxy.php?image=http%3A%2F%2F%5BIMGDEAD%5Dhttp%3A%2F%2Fwww.ihateaol.co.uk%2Fmisc%2Fpics%2F01.25.04-13%3A23%3A10Image2.jpg%5B%2FIMGDEAD%5D&hash=071d269e8a2179b1a12ea692d9db1ae5)
I wonder if the 1" part is the exit hole size for the driver and the diaphragm is actually 1 3/4" ?
Hope you are able to repair.
Cal
Cal
