Hi.
Any info on this speaker? It seems to be an old 16Ohm bass-driver. Maybe made for use as an "instrument/musician-amp"?
Tried google with little luck
Could it be used as a subwoofer? All I kind find is a Vas at about 300L and a Fs of 40Hz? I'm willing to Equalize and that sort of tricks.
Regards TroelsM
Regards TroelsM
Check out
http://www.jblproservice.com/pdf/Thiele Small Parameters/Theile Parameters.pdf
for ts parameters.
You can also head over to the JBL guys on
http://audioheritage.org/vbulletin/index.php
Do a search for more info.
EspenE
for ts parameters.
EspenE
Hi.
Thanks for the fast reply.
It seems to be limited by a Xmax of only 2mm.. that's probably not enough to do anything, - especially EQ'ing.
Regards TroelsM
Regards TroelsM
The K130 is an instrument driver. Useful for lead guitar or possibly blues harp.
K Series datasheet
T/S specs are
Fs = 40Hz
Qts = 0.25
Qms = 4
Qes = 0.27
VAS = 297L
P = 125W
Xmax = 0.76mm
Re = 6.3
L = 0.6mH
BL = 18
Mms = 60g
Sd = 900cm^2
K Series datasheet
T/S specs are
Fs = 40Hz
Qts = 0.25
Qms = 4
Qes = 0.27
VAS = 297L
P = 125W
Xmax = 0.76mm
Re = 6.3
L = 0.6mH
BL = 18
Mms = 60g
Sd = 900cm^2
Check out
for ts parameters.
EspenE
...oops: sorry for the double post.
for ts parameters.
EspenE
That's where I got the specs I posted earlier. I just couldn't find the file on the JBL site so copied them out of the one saved in my database.EspenE said:Check out
for ts parameters.
It's a great driver, within it's intended application.
It'll work pretty well in a properly designed reflex enclosure as long as you don't ask for really high spls at very low frequencies. Not suited to subwoofer duty due to limited xmax. I had a pair of the 16 ohm D130 in oem jbl cabinets of about 4 cu ft estimated - worked quite well.
- Jbl K130-16
