JBL GTO1201.1
The 10uf 200volt caps are bad in this amp .
I forgot how to do this .
The amp has 4 caps .
Can I use 4 polarized caps on this amp to replace the ones that are defective ?
Like solder one positive in the board hook both negatives together and solder the positive lead from the 2nd cap into the board .
If so what value caps would I need and how many volts?
