IsoTek EVO3 Premier Mains Power Cables
Due later this month, pre-orders being taken, is the new IsoTek EVO3 Mains Power Cable. Featuring silver plated cable and bespoke gold plated terminations, brand new design and the best feature of all, the price is only £79.95 more information on my website www.mcru.co.uk
The cable will be sold at a fixed 1.5 metre length, available terminations are standard IEC, high current IEC and Fig.8, mains plugs will be UK, USA and Schuko, all feature gold plated pure copper connectors, full spec. of the cable is below, anyone who wants to be first to try these can order off my website and I will post the cables the day they arrive. If you prefer to order elsewhere Isotek have now opened an on-line shop via their own website here.
You can also download and read the very latest IsoTek news Report here.
The IsoTek Premier is the first of our EVO3 (Evolution Three) power cables. It heralds a significant step up in quality of materials used and represents, we believe, one of the highest quality and specification power cables at its price point. Premier has taken two years of development. Sourcing of specialist high quality materials, designing and development of our own bespoke and unique 24ct gold connectors and extensive quality control testing and full, independent certification to BS 6500:2000.
CONSTRUCTION:
The conductors are in a parallel construction with slight rotational twist. This established technique remains the first line of defense against RFI and EMI rejection.
CONDUCTORS:
Silver plated 99.9999% OFC conductors offer an exceptional level of purity with enhanced conductivity. They are less likely to fracture or degrade over time. Silver is an excellent conductor and when combined with a high purity copper provides impressive electrical properties.
DIELECTRIC:
Teflon FEP dielectric (insulation) is chemically inert and has a very low dielectric constant over a wide frequency range. FEP possesses a very high degree of stress crack resistance and a low coefficient of friction making it an exceptional dielectric. FEP is the first choice for safety in both temperature and electrical insulation.
FILLER:
Cotton filler has been used to give the cable internal strength and reduce microphony. Cotton also possesses excellent dielectric properties, the best of a solid material.
WRAP:
A paper wrap is used to secure the construction prior to the application of a flexible PVC jacket. The addition of the paper and cotton form a buffer with the PVC so as to maintain exceptional dielectric properties.
JACKET:
PVC is used as an outer jacket to give a high degree of flexibility and mechanical strength.
TERMINATION:
Premier cable is terminated using IsoTek’s bespoke Audiophile grade moulded connectors of solid OFC with 24ct gold plated conductors. These offer the highest quality performance and will not tarnish.
In conclusion, IsoTek Premier uses high quality materials with intelligent construction to deliver a power cable of outstanding performance and mechanical integrity, which will not degrade over time or break your bank balance.
First pictures of the new UK versions of the IsoTek EVO3 Premier Mains Leads.
More information is here.
