isolated supply grounding
I am interested in using a isolated/seperate supply in my amp. I am not sure about the grounding . Iknow I will use a single ore multiple star
topology. I will have a ground buss for the output cuircuit , and one for the input circuit . the grounds for each run back to the power supply unit and connect to chasis ground , do you have to have a chasis ground on the amp also ?(besides the mains ground)
Jeff
