hi, can you tell me if this will work well with the t-amp ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5819985384&rd=1&sspagename=STRK:MEWA:IT&rd=1
if not , what would be better ?
thanks, james.
thanks, james.
Well, you can get this one instead
http://cgi.ebay.co.uk/12V-DC-5A-DES...QQitemZ5822892954QQcategoryZ176QQcmdZViewItem
Its the same but 5A and you can probably get it cheaper as I got one from this seller for 1.04£ plus shipping! 😀 Unfortunatelly my 41 Hz Amp3 is still not fully assembled...
Cheers!
Cheers!
Looks good James. Best of luck!
Just test to see that it doesn't send too much hash back into the mains - that could get into your other audio gear.
istari knight said:Very true , michael mardis said the same.
Hey, that's me! 😉
surely it cant be as bad as a standard wallwart ?
Could be worse, at least as far as sending noise out into the mains. It is likely to be better than a standard wall wart for supplying the amp.
Let us know what you think when you get it.
hi again - just another question for you......
ive bought an alps pot so i need a seperate power switch.....
ive got one from my workshop but its rated at 2A-250v & 4A-125v
its one of those toggle switches , is it compatible ? or do i need something bigger ?
im in the uk btw so its only rated at 2A
thanks for the advice !!
- Class D
- Is this transformer suitable for a sonic t amplifier ?
