Is this Fresnel any good ??
This is a HIGH RESOLUTION Fresnel with more than twice the ring density of a normal lens. It's wide format also makes it suitable for use with a widescreen monitor for Fresnel VR applications or for use as an image projecting lens!
Specifications:
Thickness: 1.5mm
Size: 400 x 320mm
Weight: 280 grams
Material: optical acrylic
Groove pitch: 0.2mm (127 grooves per inch)
Focal length: 550mm
£14.99 GBP
