When you spend an hour moving somethings around to make it look nicer and standardize wire colors. And you turn it back on and it’s humming like crazy. So you undo all your changes and turn it back on and it’s just as loud and you wonder what you screwed up. Then you realize you forgot to plug back in the input source and your initial changes were probably fine all along.
I am SpartacusThen you realize you forgot to plug back in the input source and your initial changes were probably fine all alon
