I have been wondering why music played via loundspeakers sound better when played with a live feed directly from a microphone than when played from a recorded source - even 24 bit high resolution.
What I am really wondering is What would it take to design/build an A/D and D/A that would sound more like a direct feed. Just as an experiment. Forget about being practical. Even if it took 1 Tb to record a song, or fraction of a song. Here's what I am thinking. Make the D/A as simple as possible. Remove all filters, algorithims, etc. Starting at the beginning, the microphone converts air pressure flucuations (music) to voltage. Record the voltage from the microphone at a very high sample rate (whatever it takes for this experiment) and at high precision (again, what ever it takes). For playback, reverse the process. Convert the data back to voltage. No filters, no algorithims, just reverse the process as simply as possible. Make the sampling rate high enough (again, what ever it takes) that we do not need to guess what is happening between data points. Then feed the signal through our stereo preamp, amp, and then to loudspeakers.
Does any one know how to perform such an experiment? Just for fun.
Dan
Dan
Does it ?
I imagine having the performer live in front of you could skew your perception quite a bit.
Yeah, I'm leaning towards "silly question" too - a lot of pro audio is done via digital mixers these days, which are an ADC>DSP>DAC system - no-one I know thinks they sound worse. I suspect you just have an unconscious live performance bias.
No - there is a real difference: Dynamics!
All recordings (yes all!) use dynamic compression. That is the reason.
Ask a local studio-technician if he could show you how he works one day, and a whole new world appear for you.
A lot of instruments actually sounds better with some compression, and he ofcourse also have to watch the limited dynamic range of a 16bit CD (96dB).
...and then there is the whole "loudness war" thing.
Even with 24bit sources (which has more than 130dB dynamic range) technicians seldomly use the extra headroom to the max. Probably both because of clipping risk and 'perceived' sound quality.
I used to do the "live vs recorded" experiment a lot. Live feed always sounded better. Why? Same gear, same speakers, everything.
Then one day I realized. The recordings were missing the direct sound from the stage. Doh! Even tho the direct sound was low compared to the amplified, it still added a nice realism.
Only did the isolated musician test once. Live feed still won but by a much smaller margin.
What I was alluding to with the digital mixer comment is that there's an easier way to do the comparison: compare a direct live feed to a live feed with an ADC>DAC in the middle of it. Personally, I'm willing to bet that in a blinded, level matched test, very very few people would pick the difference.
Thanks to everyone for their replies. The February edition of Stereophile, page 3, touches on this topic. I really don't have any direct experience with digital recordings, but it would seam that the live feed has an advantage because the music is presented whole. The digital version takes the music and breaks it into pieces, filters it, tries to guess what data is missing between the data points, and then tries to put it back together again in an analog form. As good as high resoulution digitial is, the music is affected by the process.
If any of you are D/A experts, is it possible to eliminate all of the filters and algorithims and just create a voltage for each data point?
Dan
Dan
That's basically what a non-oversampling dac with no output filter does - produces a "stepped" output corresponding to the samples. But since you're now playing back a square-ish wave, you're introducing higher harmonics (which your loudspeakers probably won't reproduce, but some people worry about it).
Could you explain why it would introduce higher harmonics?
The second question is: If we live with the stepped output, how small does the step have to be to be inaudible? How would one decide? Just out of curosity, what is the sampling rate of HDTV? Audio is 16 bit-44.1 KHz up to 24 bit-192KHz. What is video? Is there any corelation between the sensitivity of the human eye compared to the human ear?
75MHz with the data 20 or 30 bit parallel.
Wow - that is a lot of data.
So, recording and play back of high resolution high sample rate data already exist (video), could audio be recorded and played back in the MHz range?
I see you are from North Carolina. I lived there for 12 years and loved it.
Excellent - Of course we are not recording a source that is in the MHz range, but you are correct in that the microphone would need to be able to react to a very fast step changes in order to take advantage of high speed recording. Thinking about this for a second, since a lot of people prefer analog playback to digital playback, maybe the microphone is not the issue. I am just guessing, but maybe it is the density of the data. At 20 kHz and 44.1 KHz sample rate, the density of the data is extremely small.
Does any one know of an economical way of recording audio and play back at extremely high sample rate (MHz) - just for fun?
Wow - that is a lot of data. So, recording and play back of high resolution high sample rate data already exist (video), could audio be recorded and played back in the MHz range?
I am just guessing, but maybe it is the density of the data. At 20 kHz and 44.1 KHz sample rate, the density of the data is extremely small.Does any one know of an economical way of recording audio and play back at extremely high sample rate (MHz) - just for fun?
No point. 24bit 48kHz recording provides a recording medium with dynamic range better than human hearing and resolves the input signal such that you couldn't distinguish it from any higher sampling frequency. That is, if you did a double blind test with two signals, one encoded/decoded at 48kHz, and the other at 96 kHz you wouldn't be able to tell the difference. So higher sampling frequencies (or bit depth) are not required.
I think I could learn a lot by doing a live vs memorex (remember the commercials from the 70's) experiment. What kind of equipment would I need to compare a direct feed from a microphone to a recorded signal?
Thanks to everyone for thier response. I will do a little research on recording equipment, microphones, etc. If you have any suggestions, I would like to hear from you.
Dan
Dan
I've done a little "Live vs Tape" in real time with analog tape. Just using the monitoring function. Usually not listening for the differences, just checking to be sure that the tape was OK.
You should be able to do the same with digital, I suppose. Never tried it.
- Digital Line Level
- Is this a silly question?
