Is there another way in Ltspice to see the slew rate of a schematic ?
Hello
I use the settings like you can see in my image, it show more a square wave than a real slew rate measuring, since the frequency response affect the slew rate square image and result.
Thank
Bye
Gaetan
The small signal frequency responce, input RF filter gives wrong slew rate. You can step the frquency with maximum output before clipping to measure the power bandwidth. The -3db gives a better slew rate estimation, but not distinguish rise and fall.
