Hello,
I hope here somebody can answer my question.
If i take a AD1865 DAC and feed it without a Digital-Filter with the
Data, both L+R, the Clock and use a inverter to feed the Latch-Left-Channel with the inverted WS and the Latch-Right-Channel with the original WS.
Do I become here some kind of time shift in cause of the little dfference, when the right and left Signal is given free ? It´s a 44.1 kHz Signal, the
WCKO, right ? Or is this not inportant for the correct funktion.
I hope you understand, what I mean, and hope for a interesting answer.
Best regards from bavaria, 🙂
Manfred.
Manfred.
The right channel will lag 11.228 us behind the left which corresponds to a speaker placement difference of 4 mm at 340m/s speed of sound.
Can be neglected for all practical purposes.
Greetings from Oberbayern.
